P0089 code fuel pressure regulator
Old Jun 28, 2020 | 10:56 AM
za16's Avatar
Default P0089 code fuel pressure regulator
My 2012 S60 T5 2.5 liter’s check engine light is on. The code that comes up is P0089 and it says the “fuel pressure regulator 1 performance”. I’ve changed out the fuel pressure sensor. I don’t think my Volvo has an external fuel filter, or at least I couldn’t find it anywhere and it appears I have a metal fuel tank. I’ve noticed no issues driving it and I’m not sure of what else it could possibly be. Any help would be appreciated.
Old Jun 28, 2020 | 11:05 AM
How many miles are on the car? If you clear the code does it reappear or randomly over time? It could be several other things - a car voltage issue (make sure the battery is maintaining 12.6+ V ), ground wire issue, connector to the sensor, wiring to the pump, the pump itself etc.
Old Jun 28, 2020 | 11:20 AM
za16's Avatar
It’s at 86,000 miles. I’ve had no issues before this and it gets a regular service. The code usually reappears after I drive the car around on and off for a few hours. The light doesn’t come back on right away, no jerking, stalling, or any other performance issues; the light just won’t turn off.
Old Jun 28, 2020 | 03:48 PM
is there a correlation to how much gas is in the tank? does it seem to happen the same when driving around full vs empty?
Old Jun 28, 2020 | 11:01 PM
za16's Avatar
it happened when the tank was full and when it was half empty.
Labs07
Jun 25, 2019 01:56 PM
Mcbride85
May 9, 2018 04:56 PM
ThomasK
Mar 4, 2012 09:38 PM
the tenor man
Dec 5, 2011 09:20 PM
soapboxhero
Oct 12, 2006 03:19 PM
