P0305 cylinder # 5 missfire on 2.3l turbo engine
Old Mar 22, 2016 | 03:51 PM
Nick2.3's Avatar
Default P0305 cylinder # 5 missfire on 2.3l turbo engine
Hello first timer with this forum and first timer owner. I have a 2001 Volvo S60 T5 and recently acquired it. I knew the camshaft position sensor had been bad and so replaced it. It runs a little rough still and I had put my OBD II scanner on it and the code p0305 cylinder #5 missfire. Has anyone else had this problem and what have you done that has stopped this problem from coming back?
Old Mar 22, 2016 | 09:45 PM
ssicarman's Avatar
Coils are a fairly common failure. Swap the #5 coil with another cylinder and see if the misfire follows the coil.
Old Mar 23, 2016 | 05:08 AM
Nick2.3's Avatar
OK, thank you I will have to try that
BrwMstrHRx
Jul 3, 2015 09:24 AM
christopherandrews1989
Mar 29, 2014 10:20 AM
nmt0m35
Jan 8, 2013 08:13 PM
tr_car_nut
1998-2000 model year XC70
Nov 5, 2012 01:51 PM
petes99xc
Aug 7, 2007 07:58 PM
