Part number for plastic piece in door
Old Feb 27, 2009 | 03:04 PM
dewdog1978's Avatar
Default Part number for plastic piece in door
The passenger window on my 2002 S60 came off its track. I opened up the door panel and fixed it, little green plastic track guide came off. Inadvertently, I broke this black plastic piece that is attached to the inner door panel. I had tried to remove the door release cable, but one of the plastic clips that holds it in place broke. The front passenger door does not open from the inside. I just do not know what to call that piece when ordering the replacement. What is the part # that I need to reorder this plastic molded piece?
Thanks for the help,
dewdog1978
Old Feb 28, 2009 | 07:04 AM
If it is attached to the door panel most like you need the entire door panel.
If it just won't hold the cable I have at times drilled a small hole towards the back and used a small wire tie to hold it into place.
Old Mar 3, 2009 | 10:28 AM
dewdog1978's Avatar
Thanks for the suggestion.
volvo305
Feb 16, 2017 09:50 PM
zacharyherin
Mar 5, 2010 11:36 AM
ksu850
Mar 3, 2010 01:07 PM
timwu12
Jan 27, 2010 01:15 PM
pawn256
Mar 17, 2006 07:51 PM
