Popping noise when hitting bump
Old 01-06-2007 | 02:15 AM
grand94jeep's Avatar
Default Popping noise when hitting bump
I'm hearing a fairly loud bumping noise in the front suspensionwhen hitting bumps at slow speed. What might it be and would I be able to repair myself?
Old 01-06-2007 | 01:54 PM
Default RE: Popping noise when hitting bump
Usually the 2 things that cause this is.
1.Sway bar links bad. (easy to fix)
2.Upper spring seat on strut.(more complicated to fix)
To check the upper spring seat open the hood and get a 13/16 wrench and try to turn the top nut for the strut. If it turns easy it is bad. If it feels rubbery and bounces back it is good.
Old 01-06-2007 | 06:05 PM
Thanks.
jonathanvolvo
06-27-2011 03:57 PM
sdehaven4
05-25-2010 09:23 PM
Dionepsoc
07-21-2009 12:17 AM
llcj16
11-14-2008 07:15 AM
oragame
07-22-2005 12:42 AM
