Position Light Out (not)
Old Feb 23, 2010 | 04:26 PM
SusanW's Avatar
Default Position Light Out (not)
I often get a message that a position light is out--we will check every light we can think of--and all are fine. Any thoughts on this? I'd love to be able to fix it if it's an easy fix.
Old Feb 23, 2010 | 04:52 PM
Anjow's Avatar
I saw it mentioned on another forum that this is very common, and that just re-seating the bulb may prevent it. Have you tried that?
I had the same message last week, but mine really was dead and after testing to make sure, I replaced it. It was the lower of the two red/orange lights at the back (in my case on the left), 12V 5W.
Old Feb 24, 2010 | 05:32 AM
crespo's Avatar
There are 2 bulbs per side in the rear lights. Sometimes one has blown but it is hard to spot because the other is still illuminated. Take a closer look and make sure you can see 2 bulbs lit.
Old Feb 25, 2010 | 08:52 AM
ikey's Avatar
Check for corrosion on the contacts when you pull the bulbs; they may need cleaning. A thin coat of dielectric grease helps keep moisture out. You could also check the assembly's connector.
LRM2
2001-2013 model year V70
Mar 31, 2015 05:45 PM
michellefreelife
1998-2000 model year V70
May 17, 2013 09:34 PM
tdub
Feb 1, 2011 01:19 AM
ryanhill376
May 10, 2009 12:46 PM
Scott6
Aug 13, 2008 06:12 PM
