Power steering pump - hard steering
Old Jan 25, 2023 | 11:34 AM
Bessarion's Avatar
Default Power steering pump - hard steering
Me again.
2006 S60 2.5T.
We had the power steering pump replaced recently (last week) due to a leak. The pressure/return hoses leak slightly, but the reservoir is full. After less than a week, my son told me he practically lost power steering. Before I replace the hoses, should I clean or replace the reservoir? can the filter be clogged up?
Old Jan 26, 2023 | 02:00 AM
johnwick3499's Avatar
well if you says that your power steering becomes inactive, then i suggest you to check the oil in the reservoir when you have not started your vehicle for more than 12 hours because when we start the engine then due to pump it seems like oil is full but it's not actually. Please check your reservoir.
Old Jan 26, 2023 | 06:41 AM
Bessarion's Avatar
Thanks, will do. The other thing I found out is to make sure the lower u-joint on the steering column is properly lubricated.
denti
Nov 19, 2018 10:07 AM
morphixx
Sep 21, 2017 10:43 PM
Garry B
Dec 29, 2012 03:58 AM
claya
Mar 30, 2008 12:33 AM
laroqet
Jul 27, 2007 05:13 PM
