2.5t power steering fluid.
Old Jan 24, 2023 | 04:01 PM
Bessarion's Avatar
Default 2.5t power steering fluid.
Just picked up the the car from the mechanic after steering pump replacement (hoses are leaking, presumably). After a day or two the steering is "notchy" again. I checked the fluid level and it was OK, but then I noticed the color of power steering fluid was dark red-brown. Almost black. As compared to the clear fluid I just bought. Does it mean somebody filled up the power steering reservoir with the ATF fluid? How do I fix it?
Old Jan 26, 2023 | 06:24 AM
Dingus1's Avatar
Someone indeed did put atf in there. You need to drain all that out and put the correct Eurospec power steering fluid in. Stuff I bought was green I think, but I don't think power steering fluid is strictly color coded.
https://www.fcpeuro.com/products/hyd...-liter#fitment
Another fluid I used on the same car.
Old Jan 26, 2023 | 06:44 AM
Bessarion's Avatar
Yes, I bought the good stuff. How do I drain it? I read somewhere to disconnect the return line from the reservoir and start turning the steering wheel while refilling the reservoir with the correct stuff. The question is do I do it with motor running or the motor off?
Old Jan 26, 2023 | 09:41 AM
Yes to do a flush you'd have the motor running to use the power steering pump to push the old fluid out while you put new fluid in the reservoir.
here's a handy link that explains the procedure
https://gobdp.com/blog/perform-power-steering-flush/
westsacxj
Jul 13, 2017 07:50 PM
MSGTUSMC
Nov 4, 2016 10:24 AM
tmixdorf
Aug 31, 2009 08:25 PM
nmwagon
Aug 29, 2007 05:14 PM
