Questions about front hood and timing belt of 2009 S60
Old May 5, 2019 | 06:02 PM
chen3hu's Avatar
Default Questions about front hood and timing belt of 2009 S60
Hi, everyone,
Thank you for reading!
I'm new here. Recently I came across a tricky problem: the engine hood cannot open. I tried to pull the lever on the left bottom of dashboard yet not sound or action happened. I tried to pull the lever and lift the hood simultaneously, still the hood wouldn't move. Could anyone please help me by giving me some clue on what's going on?
Besides, mine is 2009 and has less than 90k miles. Shall I prepare to replace the timing belt now or I shall wait to 120k miles which is recommended in the maintenance manual?
Thank you so much for your help!
Old Jun 11, 2019 | 09:31 PM
08s60's Avatar
Don’t know what’s up with the hood. You might take it to a body shop, they can probably figure out the issue.
I would wait until 120k or 15 years to replace the belt.
Old Jun 12, 2019 | 08:56 AM
timing belts are due on most white blocks at 10 years / 120K miles. Important to do the tensioner and the idler as they can fail and take out a healthy belt.
Regarding your hood release, sounds like the release cable to the latch broke. Not sure of the fix for your model so google around or go to a dealer/body shop as they may need to access by removing a headlight (such as the 850s/V70s) or the grill or from under the car to release the latch and to replace the cable. Did you check to make sure the under dash level is still pulling the cable?
aconway23
Aug 27, 2019 07:40 PM
Laurie Simmons
Jul 28, 2016 07:29 AM
aceniantor
Feb 6, 2012 03:22 PM
sgtcarl
Mar 2, 2011 06:52 AM
Lichty17
Oct 13, 2006 08:28 PM
