Radiator Leak on 01 S60
A local mechanic told me my radiator needed to be replaced. Said the Volvo radiator had a problem because of plastic materials. I am replacing the upper hose and thermostat as I the only leak I can ascertain is from the top hose connection on the right hand side of the car. Has any heard of radiator problems being a common problem with 01 S60?
Aluminum radiators w/plastic tanks are prone to fail in most any application. There are a few shops that have the tools and expertise to flush the core, check the integrity of the core, and replace the plastic tanks. It is a less expensive alternative to buying new. If available, a brass replacement is another option.
I used to mechanic on on-highway trucks and that shop had the plastic tank radiators repaired and the failure rate was almost nil.
