Radiator Leak on 01 S60
Old Apr 11, 2011 | 10:25 PM
KeithS60&V70T5's Avatar
Question Radiator Leak on 01 S60
A local mechanic told me my radiator needed to be replaced. Said the Volvo radiator had a problem because of plastic materials. I am replacing the upper hose and thermostat as I the only leak I can ascertain is from the top hose connection on the right hand side of the car. Has any heard of radiator problems being a common problem with 01 S60?
Old Apr 12, 2011 | 09:36 AM
jda2000's Avatar
radiator leaks at the seams of the radiator is common in these cars, not just the '01 S60, especially a 10 year old car with high miles
Old Apr 12, 2011 | 05:38 PM
J. A. Higgins's Avatar
Aluminum radiators w/plastic tanks are prone to fail in most any application. There are a few shops that have the tools and expertise to flush the core, check the integrity of the core, and replace the plastic tanks. It is a less expensive alternative to buying new. If available, a brass replacement is another option.
I used to mechanic on on-highway trucks and that shop had the plastic tank radiators repaired and the failure rate was almost nil.
Old Apr 12, 2011 | 09:50 PM
Default Its Fixed. Another victory for a 2001 S60 owner. ;)
Thankfully the upper hose and thermostat are in and no more leaking.
Thank you both for your feedback. Sometimes it takes a while to get response.
mikeawd850
Nov 30, 2012 02:26 AM
dansbonne79
Jun 19, 2009 09:26 PM
ovlov13
Nov 4, 2006 08:35 PM
copper2
Nov 23, 2005 01:41 AM
jcmartin
Jun 22, 2005 01:01 PM
