removing fuel pump 2003 s60 non turbo
I have removed the round cover above the fuel pump and can see most of the pump, now how do I remove it from in the tank? I removed 2 black nuts holding the plastic base but could feel maybe 2 more further foward on the base of pump assembly. Does the pump itself just lift out of the plastic base? It is a metal tank.
2003 S60 metal tank
nobody has ever removed a fuel pump from an s60 before, and can help with some advice on how to get the pump out of the tank. Tech had told me there is another access cover on the rear drivers side passenger seat, but there is only a access hole no opening for the tank. the only opening I have found is under the pass side rear seat and the pump assembly seems to be bolted down with 4 black nuts 2 of which are real easy to get, 2 others you can't see and almost can't get @ them.
Anyone, anyone.
Anyone, anyone.
