Replacement 2001 S60 Battery
RE: Replacement 2001 S60 Battery
Get an interstate MT-48 battery with the adapter hose and it fits pretty good.
What we used to do at work was take a rubber mallet and on the L/S where the battery slides in tap the battery tray over some. You will see how it comes out some. Tap it about straight. Then we used to install a stud and nut instead of using the OE bolt. Then the clamp goes on tight but there will never be a worry about the battery coming loose.
silver260
05-29-2008 02:27 PM
2000, 2001, aftermarket, battery, change, interstate, jump, replace, replacement, replacing, s60, start, type, v70, volvo
