01 S60 T5 battery replacement
Old Feb 4, 2007 | 04:25 PM
TCT's Avatar
TCT
Default 01 S60 T5 battery replacement
Hi, I am new and about to be in possession of the above car soonish. Silly question: I will need to replace the battery. Can someone tell mewhether it is ok to remove the battery terminals and replace the battery with a new one without having to go back to the dealer to "reprogramme"? Thanks.
Old Feb 4, 2007 | 05:54 PM
Default RE: 01 S60 T5 battery replacement
You should be fine.
If you try to jump it that might set codes.
Old Feb 4, 2007 | 10:22 PM
TCT's Avatar
TCT
Thank you.
Old Feb 4, 2007 | 10:48 PM
Your welcome.
Once you install the battery if the remote or sunroof is inop cycle the key in the drivers door to wake up the computer.
jstarman
Feb 5, 2014 04:09 PM
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
magukev
Oct 26, 2008 07:51 AM
