Resetting the "Time For Regular Service" Message
Old Dec 31, 2006 | 04:08 AM
PAPPYBALL's Avatar
Default Resetting the "Time For Regular Service" Message
Have an 04 S60 and the "Time For Regular Service" message came up, did all the regularly scheduled service, but now i need to reset the message. How do i do that? It still comes up every time i start the car.
Old Dec 31, 2006 | 08:53 PM
Default RE: Resetting the "Time For Regular Service" Message
Search
Old Aug 12, 2008 | 11:29 PM
twowheelin's Avatar
This procedure was found in the V50 forum and seemed to work on my S60:
1. Press and hold trip odometer reset button
2. Turn ignition key to run position KPII (not the start position)
3. Wait 30 seconds or until service light begins blinking
4. Release Trip Odometer button
5. Turn ignition to off position
Old Aug 13, 2008 | 05:10 AM
las4444's Avatar
This is what works on my 40 s60r.
How to Reset Service Light Put key in ignition, push down and hold trip reset button while simultaneously turning key to position one, wait a few seconds then turn the key to position 2 (all the time holding trip reset button down.) Then service light or yellow triangle, depending on car will flash a few times and then go off.
Old Aug 15, 2008 | 03:47 AM
prm's Avatar
prm
Yep, what twowheelin said, i just did that on my 05 s60 d5, push in tripmeter, turn key to position 2, the yellow triangle will start flashing, when this happens let go of the button, you'll hear a bleep to let you know its reset, job done.
Old Aug 24, 2008 | 07:23 PM
toddfmiii's Avatar
I have tried both of the above listed ways to reset the service light with not luck. Anyone have any other ideas. I have a 2001 S60 2.4T.
Old Aug 26, 2008 | 12:04 PM
GuinnessMike's Avatar
This procedure works on my 2001 S60-T5.
Normal 0 false false false MicrosoftInternetExplorer4 st2\:*{behavior:url(#ieooui) }st1\:*{behavior:url(#ieooui) } Style Definitions table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the ignition key to position I.
2. Ensure that the trip display is on T1 and shows some miles (not zero). Press and hold the T1 reset button and wait for the odometer to set to zero.
3. While holding button, quickly turn the ignition key to position II (before mileage returns). When the previously displayed miles reappears, release the trip reset button.
Old Aug 26, 2008 | 12:09 PM
Sorry, I cut & paste the procedure and it pulled a bunch of crap text with it, procedure is a below:
Old Sep 7, 2008 | 01:47 AM
mstrplmber's Avatar
I have a 2001 s60 2.4t. My service light is on. I do not have any message. Will the method discussed here work to reset the orange service light.
Old Sep 8, 2008 | 08:34 AM
Yes, it should...and won't cost you a penny.
Old Nov 11, 2008 | 04:08 PM
gtimark's Avatar
ORIGINAL: twowheelin
Many thanks! I've been looking for this procedure. This works on the '06 s40 too.
Old Nov 14, 2008 | 12:39 PM
jmwsmith's Avatar
Yep! Your recommendations worked for me! I had to do it two times because I didn't get it right the 1st time on my 05 S60. Really helpfu! My appreciation.
Old Apr 16, 2009 | 03:57 PM
blackbrick's Avatar
Thanks, this worked for my 04 S60R
hu5ker555
Sep 4, 2014 11:03 AM
slyder10
Jan 30, 2010 08:30 PM
Volvo S 40
Nov 13, 2008 06:13 AM
taspangler
Feb 11, 2008 06:00 PM
almared6
Aug 3, 2007 10:36 PM
