Resistor/blower location
Old Dec 12, 2009 | 03:29 PM
marko's Avatar
Default Resistor/blower location
I have a 2004 S60. Does anyone know where the fan/blower resistor is located? I believe that I have a bad fan resistor. The blower works (occassionally) and when it does it doesn't shut off when the car is off. I have to pull the fuse so the battery doesn't die. I was going to start with replacing the resistor but can't find it?
Thanks, Mark
Old Dec 13, 2009 | 04:31 PM
deucetech's Avatar
If you're talking about the climate control fan and resistor, then they are one unit and they must be replaced together. They are below/behind the glove box. How long does the fan stay on? There is a setting where the fan continues to blow when the car is off to dry out the A/C ducts, although it would have to be changed by a professional.
Old Dec 14, 2009 | 07:37 AM
marko's Avatar
Deucetech, thanks for the reply. I was able to find it. It is located behind the glove box and it does unplug from the blower and can be replaced. I was able to order a new resistor from partsgeek.com for $97.00.
Thanks, Mark
Bmyrthil
Oct 22, 2016 02:37 PM
Svanberg
Jul 21, 2010 04:10 AM
jmallie
Sep 17, 2009 09:47 AM
Evo 850
Nov 24, 2007 05:25 PM
robsons
Nov 16, 2007 01:05 AM
