Return of Crank Sensor code
Hi Folks, 2006 S60 2.5T, 176,000mi. I had been experiencing intermittent hard starting for a little while, and back in February finally got a P0336 Crankshaft Position Sensor A Circuit Range/Performance code, along with the "Reduced Engine Performance" message. My Volvo shop replaced it along with the connector and some wiring. The same code and message re-appeared the other day after I thought it would turn over but did not. The next time I started the car, the error code cleared. Any other ideas?
You are more than welcome to replace more sensors, but I wouldn't doubt it being off time. One tooth can cause start problems, but with VVT it can run fine once started. It does not take a lot of work or time to check the timing marks and the mechanic can use VIDA to run a timing check as well to make sure everything is working and lined up.
