rough idle on 02 s60t
Old Jan 17, 2006 | 03:27 PM
spinningcain's Avatar
Default rough idle on 02 s60t
I just purchesed my wife a 02 s60 t about a month ago yesterday I drove it and noticed that it idles rough also it makes quite a bit of noise almost like a slight knock is this normal? the car only has 24000 miles on it and is still under factory warrenty any advice will be greatly appreciated
Old Jan 17, 2006 | 04:44 PM
jks2's Avatar
Default RE: rough idle on 02 s60t
My 02 S 60 is not turbo, but I've never noticed a rough idle. Don't really have any idea what might be causing it.
Old Jan 17, 2006 | 05:11 PM
Ya I talked to a local volvo repair shop he said to try some injector cleaner well see if it works thanks for the response.......Jerry
Old Jan 17, 2006 | 09:35 PM
Make sure they clean the throttle body as well.
Old Jan 17, 2006 | 10:21 PM
ya he mentinod that but with only 25000 miles on it would it be normal for it to be gummed up already? thanks for the response.......Jerry
Old Jan 17, 2006 | 10:58 PM
These newer cars are getting Gummed up at like 15k.
In MY Opinion it should be done every 20k.
The throttle body's are setup so fine and take minor readings and can get messed up with a minor film of carbon.
Old Jan 19, 2006 | 10:40 PM
Thanks tech
finaddict4
Oct 6, 2009 08:49 PM
phoneman
Jan 4, 2007 02:43 AM
spinningcain
Jan 19, 2006 07:56 PM
johnoswald
Jan 9, 2006 08:50 PM
NEED4SWEDE01
Jun 28, 2005 10:34 PM
