Rough idle at first start-up
Old Jul 13, 2009 | 04:52 PM
Nataku's Avatar
Default Rough idle at first start-up
I have an '01 S60 T5 with 120k on it. It just recently has had a sort of rough idle for the first 3-4 seconds upon the first start up of the day. I watch the tach and it sits right at 1k but this happens so quick I don't think registers. I can feel the whole car shutter - kind of like when you stall a manual car by letting off the clutch when in gear, except the car doesn't actually stall - just shutters for about 3-4 seconds. I haven't had any issues later on in the day, just after it's sat overnight. Any ideas?
Old Jul 13, 2009 | 07:59 PM
JP's Avatar
JP
A few of us have had this problem. Here's another thread on it:
https://volvoforums.com/forum/volvo-s60-v60-10/sputtering-start-need-opinions-please-31427/
Old Jul 13, 2009 | 10:58 PM
Nataku's Avatar
Well I guess it's good to know that I'm not the only one with this problem. Has anyone found a fix for it? I was also going to try new plugs....
Old Jul 26, 2009 | 11:34 AM
Oli ovlov's Avatar
Default Did you try this
Hello all,
I have had the same issue with my 97 850 at around 215 000 km. I had PCV work done, clean and replace parts but not at the dealer as the are very expensive (over $1200). PCV system is located inside the engine.
PCV is a lot of labour as the intake has to be taken off and fuel line disconnected. Not really a DIY unless you have the tools and a whole day and soem knowledge of the engine.
Hope this helps.
djforresta
Jul 4, 2010 11:15 PM
rosesforlily
Nov 5, 2009 09:23 AM
volvomang
Aug 23, 2009 02:13 AM
yank50
Mar 14, 2009 11:15 AM
