S60 2002 broken timing belt
Old Jan 20, 2022 | 07:34 PM
sebas60's Avatar
Default S60 2002 broken timing belt
Hi i Buy a s60 with timing belt broken, i change the valves for new, and never make the adjust, and won't start, late i Buy a special tool for lock cams and for pressing the camshaft and make adjust, the problems is that all valves are too long and the solid lifters don't have clerance.i wanna know ir the valves is correct, because the seller told me that engine is a 2.4 but i put the vin code and says that is 2.3 t5.I wanna know what is the engine model.
This is the vin YV1RS53K922143035
And this is the valves that install Intake Valves:Head 31mm X Stem 6mm X Length 104.3mmExhaust Valves:Head 27mm X Stem 6mm X Length 103.3mmPart Number:9454607 9454610
Old Jan 20, 2022 | 09:41 PM
Originally Posted by sebas60
timing belt broken, i change the valves for new, and never make the adjust, the problems is that all valves are too long and the solid lifters don't have clerance.
Sorry, I thought we discussed this a couple of months ago when you started this project. The valves are adjusted by grinding the tops of the stems down (if there is enough room, and you have a valve stem grinding machine) or by replacing the tappets with thinner tappets. The head has to be off the engine to be able to do this. Springs off, hold the cam in place with a special tool, measure clearance (if any), grind valve stem, then repeat until correct for each valve. Reassemble and you have compression and the engine runs!
Old Jan 20, 2022 | 10:13 PM
sebas60's Avatar
Yes dear i have this car for some months ago and still won't start
Old Jan 21, 2022 | 10:03 AM
did you check the compression?
sebas60
Dec 1, 2021 08:09 PM
daver
Dec 5, 2016 12:10 AM
DeanH
Jun 26, 2012 12:43 AM
DeanH
Jun 23, 2012 04:05 PM
Jakeman
Mar 4, 2010 05:46 PM
