S60 Cambelt replacemnt
Old Jan 27, 2011 | 03:13 AM
Brent77's Avatar
Default S60 Cambelt replacemnt
I have just replaced the cambelt as per the book, the car is now not going very well at all, i have checked and re checked, even repeating belt fittment producures. The vvt on which is only on the inlet cam, i can move the cam gear by hand, to me this cannot be right, not sure what to do from here. Could ther be a problem in the vvt broken spring or something.
Thanks
Brent7
Old Feb 3, 2011 | 10:25 AM
ibanez958's Avatar
if you are changing the t-belt only, you don't really need to lock the cam as long as you marked the right timing before you took the belt off, also by the time you had the belt off, don't move the camshaft timing then you should b fine. after belt installation, did u the engine by hand to change if you got the belt on right??
Old Feb 4, 2011 | 11:34 AM
Brent: Your question is not clear. What motor does your car have? Turbo or Non? Did you use any specific instructions when doing the belt? What parts did you replace? Have you tried to start the car? Have you turned it over by hand? Did you make sure timing marks were aligned when you started? What are you needed help with?
Old Mar 16, 2011 | 09:44 PM
s604now's Avatar
Brent, did you fix your problem with the CAM belt?
I am having a similar problem on my 01 S60.
Does anyone have a pdf which shows how to align the timing marks?
Old Mar 16, 2011 | 09:52 PM
What instructions did you use to replace your belt?
prineshkv
Mar 23, 2015 02:13 PM
Hawk239128
Mar 31, 2011 02:37 PM
ben watson
Feb 19, 2010 08:56 AM
chetman2005
Nov 2, 2009 08:03 PM
mr2440davies
Aug 18, 2008 09:16 PM
