S60 Front Brakes
Old Sep 4, 2010 | 09:33 PM
stevo's Avatar
Default S60 Front Brakes
Can anyone help? I have a 2005 S60 & I can't get the front calipers up enough to remove the pads. I also need to swap the rotors out.
Old Sep 4, 2010 | 09:40 PM
Did you remove the allen screws all the way?
Did you remove the anti rattle springs?
You need to back the allen screws out all the way and the caliper will slide off.
Then you remove the caliper bracket then rotor.
Old Sep 5, 2010 | 09:48 AM
stevo's Avatar
I know it should be that simple but I can't seem to get the pads to release enough to allow for removal of the caliper. ??
Old Sep 5, 2010 | 03:52 PM
HMM not sure without seeing it then.
Old Sep 6, 2010 | 08:36 PM
Delirious's Avatar
drive a flat screwdriver between the caliper and the pad, this will compress the caliper piston enough to wiggle the caliper off the brake pads.
here is a link: http://volvospeed.com/Repair/s60_rbrakepads.html
mrvolvos60
Sep 11, 2014 07:39 PM
tinto99
Apr 11, 2011 05:09 PM
mo t5
Mar 9, 2006 01:56 AM
giacomozzi
Feb 28, 2006 12:48 AM
Lichty17
Sep 3, 2005 06:37 PM
