S60 Harsh Shifting Transmission into first gear
Old Feb 1, 2024 | 09:51 AM
lawkr's Avatar
Question S60 Harsh Shifting Transmission into first gear
Hello,
I have a 2014 Volvo S60T5 and it is starting to periodically give a hard shift into first gear when I stop at a traffic ight etc.
I have read that the is a software update and then a complex re-adaptive driving sequence performed by Volvo. Has anyone had this same issue and did the SW update etc. fix it.
Thanks Ken
Old Feb 1, 2024 | 10:44 AM
A software update will not fix your problem.
The adaptation process is used - to teach the control unit how to produce the smoothest shifts. It is done when a new transmission is installed as it is the quickest way to do that.
The control unit constantly self adapts as you drive. So at this point your TCU is doing the best it can.
A good first step would be to examine your trans fluid. When was it changed? To solve problems like this most start with a or several drain and fills or a flush. If that does not help you may have a valve body problem or worse. (you will read about a servo cover - that does not apply to your car)
Google "gibbons method" for ideas on how to change your fluid. You should only use the proper fluid, fluids that are recommended in the threads you read - not something random off the auto parts shelf that "says" it's compatible. And DON't try any aftermarket additives, you might regret it.
Old Feb 1, 2024 | 09:06 PM
lawkr's Avatar
No I have not changed or flushed the transmission fluid. I have one scheduled for next week. Lets hope it works.
Old Mar 31, 2024 | 11:47 AM
boz's Avatar
boz
Default Shift problem
Have you fix the car? I have the same problem hard shift at take off. Oil change didnt fix the problem.
Import-Era
Sep 2, 2009 07:01 PM
cowartdo
Sep 1, 2009 06:57 PM
gatorbrit
Mar 20, 2009 10:06 PM
m_schiff83
Jan 6, 2008 09:08 PM
sclark60
Oct 18, 2007 12:46 AM
