S60 R WON'T START
Old Oct 20, 2008 | 08:29 AM
epbuku's Avatar
Default S60 R WON'T START
This morning after starting car itimmediately stalled, now it just turns over. Message indicator says reduced engine performance. Have had no previous issues.Please Help!
Old Oct 20, 2008 | 08:49 AM
Default RE: S60 R WON'T START
Is there also a message that says start prevention try again?
Do you have another key you can try?
Old Oct 20, 2008 | 09:01 AM
epbuku's Avatar
no other message, and yes i tried other key just continues to turn over>
Old Oct 20, 2008 | 09:02 AM
You will have to check and see if the fuel pump is working. There is a schrader valve on the end of the fuel rail under a Blue cap. Press it in and see if fuel comes out.
Old Oct 20, 2008 | 09:08 AM
epbuku's Avatar
Yes fuel did come out.
Old Oct 20, 2008 | 09:17 AM
Ok then sounds like the fuel pump is working. You really need to test for spark but on your car it will take 30 to 40 minutes to get into there just to test for spark.
You might want to try to borrow a scanner or something to read codes.
Old Oct 20, 2008 | 11:19 AM
epbuku's Avatar
thanks so much i'm working on getting scan tool.
thanks again.
Old Oct 20, 2008 | 11:37 AM
Default RE: S60 R WONT START
No problem I hope it pulls codes and gives us a direction.
Old Oct 21, 2008 | 07:45 AM
epbuku's Avatar
Scan tool gave no codes. Just checked fuel pressure, and recieved a 0, and no fuel is coming out of valve this morning, I'm guessing when I checked valve yesterday there was still fuel in the line?
Old Oct 21, 2008 | 08:46 AM
That is very well possible.
You could have a bad fuel pump. To bad it wasn't cracked and leaking because Volvo just extended the warranty on it due to the nipple that the fuel line attaches to cracks and leaks.
Do you smell gas at all by the passenger side rear of the car?
Old Oct 21, 2008 | 09:19 AM
epbuku's Avatar
Unfortunetly I don't smell any fuel.
Old Oct 21, 2008 | 09:33 AM
I doubt they would do anything but it wouldn't hurt to contact them and ask.
Old Oct 24, 2008 | 04:58 AM
epbuku's Avatar
Hello, I pulled the rear seat, ( no cacked nipple) The pump is not recieving any power. I checked the fuses (all good). I was told there isn"t A fuel pump relay, but there is A fuel pump control module? Do these usual go bad, where is it located? Thanks for your help! ( Is it poss. to test control mod ) Thanks!
Old Oct 24, 2008 | 07:30 AM
Well im not sure of your cars year. But I looked up a 2003 S60 turbo there is a fuel pump relay.
See pic below I marked the relay with a blue arrow.
Old Oct 27, 2008 | 09:25 PM
epbuku's Avatar
Hi Tech, changed fuel pump relay this morning, my baby is once again purring like a kitten!!! I can't thank you enough for your help! If your ever in the Woodstock Ct. area please let me know, I owe you big time (at leasta cold one or two)! Thanks again!
Old Oct 27, 2008 | 09:35 PM
Glad thats all it was and it is running good now.
If I am in that area I will look you up. Cannot do the cold one though sorry but I don't drink.
But atleast we could meet up. Once every couple of years I go to NJ to maybe we could do something to meet up next time I am up there.
About 3 years ago I bought a Van off e-bay from up there. My brother drove it down to me here in FLA.
Or if you ever come to Orlando let me know and we could still meet up.
Gustav
Nov 11, 2017 01:01 PM
volvoralph
Jul 19, 2016 04:19 PM
hokiedave
May 4, 2009 12:37 PM
exotek
Nov 11, 2008 09:32 AM
