s60 scanner question
This scanner will reset SRS codes as well as other codes
http://www.esetuning.com/BSR-PPC-Dia...c-volvo-ds.htm
I have one and it works. I do agree with Bender though if you keep getting the SRS code more than likely something is wrong and more than a reset needs to be done.
A disclaimer on the scanner above, it is for most models 01-07 but there are a few exceptions noted on there website that it will not work with.
