S60 Transmission Noise - Bearing??
Hello Guys,
My first post here. Thanks for the amazing forum.
At about 6k miles ago, after a normal service (oil change), I start hearing a bearing noise. My car has now 44k miles on it.
First mechanic changed the wheel bearing, vainly, nothing change!
Second one, diagnosed it as a noise coming from the gearbox (transmission), specifically from the differential bearing of the transmission. Not a differential found in a AWD cars.
He told me that to be sure, he would need to open the transmission and check it. But after examining a bit more, he told me it’s better just leave it like this. The bearing is making noise, but it’s not worth it to open the transmission to repair.
Attached you can find two videos. One shows someone rotating the tire with the engine off.
The other one show the noise happening right after I turn the engine off.
What can it be? If it’s the transmission bearing, where can I buy a replacement bearing?
I hope someone can help me!
thank you all!
2016 S60 R-design T6 FWD
Engine - B4204T9 - 2.0 4 cilinder turbo
Transmission - Aisin TG-81SC
thank you all!
