S60 VVT code issue
Old Mar 30, 2014 | 04:45 PM
s60t5man's Avatar
Default S60 VVT code issue
So I am getting a code for the VVT solenoid i believe from research, the code P0013.
From what I can see to check if the solenoid if it is bad the resistance will not be 3.7Ohms.
I am trying to figure out whether mine is broken, as it is measuring at 4.1 Ohms. I also had picked one up from a parts yard for a few dollars and it has the same reading, 4.1 Ohms and does not work, however I have no way of confirming whether it was broken or not before it ended up in the yard.
If I am getting a larger reading that 3.7 does that mean it is broken? If they are both fine I am thinking it must have to do with faulty wiring, which I have yet to find in my car. I am just wondering if anyone can confirm the Ohm reading before I purchase a new VVT sensor from volvo.
arthurdentx
Oct 25, 2019 08:18 PM
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
alexxc70
Jun 6, 2011 06:12 PM
alexxc70
May 20, 2011 11:53 AM
fixing4friend
Dec 3, 2006 11:21 PM
