S60 Whistling Noise
Old Dec 8, 2009 | 03:19 PM
SunshinyDay's Avatar
Question S60 Whistling Noise
Hi - I have an '01 S60 that has been making a whistling/whirring noise off and on for a couple of days. A friend mentioned that it might be something called the crankcase breather box and that I need to get it repaired right away.
What exactly does this part do and how much is it going to cost me to have fixed? I use a non-dealership mechanic, so I assume the cost will be less than at the dealership, but this close to Christmas I would hate to have to spend big bucks on car repairs. Can it be repaired without being replaced? Or is replacement the only way to fix it? (Unfortunately, I am not mechanically inclined and can't fix it myself. )
Thank you for any help you can offer!
Old Dec 8, 2009 | 05:48 PM
Bender's Avatar
lots of things could be causing it
first things first - WHEN is it making it? moving? idle? both?
check the gaskets around your pedals where they come through the firewall first.
Old Dec 8, 2009 | 08:47 PM
It makes the noise when its moving and when its idling. Its not a constant noise and it doesn't happen every time the car is running.
I read something about removing the oil dipstick when it is making the noise. I tried that and the noise stopped. It started again as soon as I put the dipstick back in.
I'll check the gaskets around the pedals.
Thanks
Old Dec 9, 2009 | 10:14 AM
Bender's Avatar
remove the oil dipstick - slip a condom over it, see if it suctions it in (dont let it get sucked all the way in!).
Report back.
SDozier
Mar 19, 2011 03:43 PM
apple4life
Jul 24, 2010 06:01 PM
datastreamcom
Aug 20, 2007 11:23 PM
volvo94404
May 25, 2007 06:49 AM
danielribo
Oct 23, 2005 06:38 AM
