s60 Won't Start.....help...help...help
Old Nov 3, 2015 | 02:54 AM
volvo77's Avatar
Arrow s60 Won't Start.....help...help...help
2007 s60 2.5t and had it for a week now. Here's the situation:
1st-Started car and loud knocking from upper engine, which went away after 90 seconds.
2nd-Drove about 300 feet then engine died. Tried to start but engine felt seized....would not turn at all.
3rd-Next morning added 3 qt of oil and it started....Horrible rattle/knocking coming from the upper cam area after it cranked while cold.
Old Nov 3, 2015 | 09:47 AM
volvo77's Avatar
Default Could the engine have thrown a rod...?
It car sounds really really bad now. There is a loud rattle in the upper cam area that sounds like someone dumped bolts in there
Old Nov 3, 2015 | 03:02 PM
Cdubbs's Avatar
Did your timing belt go kaput?
Old Nov 3, 2015 | 10:24 PM
pull the upper timing belt cover and have a look if the belt is intact and turn the engine over by hand to see if things seem to be working. Sounds like you could have a "sunken" or broken lifter due to running low on oil... You should check out the oil pressure sensor as well or peek in the oil fill cap after cranking to see if oil is getting to the top half. Does it start up and run at all?
Old Nov 8, 2015 | 12:37 PM
dsharp's Avatar
The engine doesn't have hydraulic lifters that bleed down.
Old Nov 11, 2015 | 03:44 AM
volvo77's Avatar
The car does start. It sounds like a v12 diesel engine. There is a knocking sound that comes from the upper engine.
Old Nov 11, 2015 | 07:25 AM
volvo77's Avatar
Angry Posted a video of the car
Click here I posted the car making the noise:
THANKS for any advice!
Old Nov 11, 2015 | 09:50 AM
pjsmithres's Avatar
That's horrible. Don't run it anymore.
Tow to dealer?
Gustav
Nov 11, 2017 01:01 PM
volvoralph
Jul 19, 2016 04:19 PM
hokiedave
May 4, 2009 12:37 PM
exotek
Nov 11, 2008 09:32 AM
