Several Issues
Old Nov 15, 2007 | 01:42 PM
ryama's Avatar
Default Several Issues
The first thing I have noticed is that there has been a strange noise that comes from the dash near the glove compartment, almost sounds like a click or something and it happens every 11 seconds or so when the car is in drive. That has been going on for several months and today i as driving and a message reading "SRS-AIRBAG/SERVICE URGENT." Is this possibly somehing fuse related? Is there anything I can do before taking it to a Volvo dealer? And would that noise hav eanything to do with it?
Old Nov 15, 2007 | 06:33 PM
jks2's Avatar
Default RE: Several Issues
Yes it very well could. I wouldn't mess around with the airbags. Dealer is your best bet in this instance.
Old Nov 15, 2007 | 09:02 PM
Does the noise go away if you change the temp of air flow settings?
Old Nov 15, 2007 | 10:12 PM
ryama's Avatar
No, I tried turning the AC on high, low, and off. Then I tried the heater on all settings, and it didn't change anything.
Old Nov 15, 2007 | 10:18 PM
If you can try to isolate a little more to exaclty where it comes from.
Old Nov 15, 2007 | 10:20 PM
ryama's Avatar
I'll try and record the sound and post it for you later, or give it a more specefic location.
Old Nov 16, 2007 | 12:32 AM
ryama's Avatar
Theres a cricle around where it sounds like the sound is coming from. Now I tried to do a video and it wasn't pretty so let me know if your going to need more to help me and I will try and do that but hopefuly this helps. It only happens when the car is in drive, and it isnt every 11 seconds it was different tonight, it happens often atleast every minute.
Old Nov 16, 2007 | 08:24 PM
HMM there really isn't all that much right there. Maybe the recirc motor.
Does it happen with the recirc on and off?
Old Nov 16, 2007 | 09:47 PM
jsherner's Avatar
I am having the same problem on my 2004 2.5t AWD and I cannot figure it out. I have had it at the dealership twice and they either don't hear it or don't feel like taking the dash apart under warranty. The exact same area. If anyone has ideas I welcome your thoughts. It happens regardless of whether the fan is on, off, hi or lo.
Old Nov 17, 2007 | 05:36 AM
mncx's Avatar
Try to put a small piece of felt tape and wrap around the hook for the latch inside glove box and see if noise goes away. The SRS messageis a seperate issue. SRS fault may leave SRS light on permanently until problems are fix... If itturned off after restarting the vehicle itsounds like u have a CAN network at the low speed side cutting out intemittently... hope that help
Old Nov 17, 2007 | 11:43 AM
ryama's Avatar
yeah the noise was the Re-Circulation i turned it off and nothing happend. thanks
Glad you found it.
wdharvey11
Oct 10, 2014 11:08 PM
ronski
Feb 24, 2013 01:21 PM
conno
Jun 14, 2011 08:02 PM
gkinser
Aug 5, 2008 06:05 PM
Psaboic
Apr 29, 2007 03:12 PM
