Sirius Satellite Radio
Old Dec 26, 2005 | 01:13 PM
Sirius Nut's Avatar
Default Sirius Satellite Radio
I have a 2004 S60 and I got Sirius for Christmas. The FM Modulator is working fine, so I don't need to hook it into my stereo. I do however need power for the unit other that than the cigarette adapter. Does anyone know where I can wire this thing to in order to power it up in a way other than the cigarette lighter adapter?
Old Jan 1, 2006 | 03:27 AM
Cementups's Avatar
Default RE: Sirius Satellite Radio
use the cigarette lighter adapter in the back of the armrest pointing toward the backseat.
Old Jan 1, 2006 | 03:54 AM
Sirius Nut's Avatar
Any thoughts on how best to run the cable from the front dash to that back adapter and keep as much hidden as possible?
Old Jan 1, 2006 | 10:39 AM
aalleoxn's Avatar
Merry Christmas Nut. Santa also brought me a sirius radio. How to run your wires depends on where you place the unit. I have the unit mounted on the dash to the left of the stereo just behind the wiper control stalk. I ran the wires from there thru the space next to the steering wheel column down to the center console and back to the cigarette lighter in the back (tucked up under the center console.
I'm actually planning on re-wiring it directly into the fuse box.
How and where did you mount/wire the antenna?
-Al
Old Jan 1, 2006 | 11:51 AM
Sirius Nut's Avatar
Thanks for the advice. I mounted mine in the upper right hand of the windshield so I could easity access it. However, that mount has created the problem as it now has a cord draping across my dash to the cigaretter lighter. I don't know where the fuse box is, but in my last car it was above my knees at the bottom of the steering column. If it were there in a Volvo, and if I could go directly to it, that would solve my problem. Would you let me know if you have any luck with this and how you do it? I would REALLY APPRECIATE it. Thanks and Happy New Year.
-- Matthew
Old Jan 2, 2006 | 02:38 PM
aalleoxn's Avatar
Mat,
The Upper right or Left? I guess it depends on if your driving on the right or left side (Euro). Either way, in my S60, the Fuse box is on the drivers side. Open the door al the way and the panel is located on the side of the dash assembly.
-Al
Dean C
Sep 22, 2012 07:56 AM
mwheaty
Jun 2, 2011 10:56 PM
S60dad
Sep 15, 2008 01:24 PM
cbgav
Sep 10, 2007 05:25 PM
muzkman
Apr 16, 2006 09:42 PM
