Solid mount upper engine crossbar deally thingy.
Old Nov 16, 2006 | 10:55 AM
adub96's Avatar
Default Solid mount upper engine crossbar deally thingy.
So i have been machining up new solid ends for the upper torque mount bar and got them done and threm them in. There is a bit of difference, it seems like the car is less prone to understeer and deflection on bumps in the corners. So that means they are doing their job. I should quit my day job and devote myself to cranking out a line of performance suspension products for Volvos. Next xtop will be billet aluminum end links.
. I'm such a dork.
Old Nov 16, 2006 | 08:36 PM
Default RE: Solid mount upper engine crossbar deally thingy.
Any pics?
Old Nov 19, 2006 | 07:18 PM
adub96's Avatar
Not really much to see just two solid cylinders of metal pressed in to replace the half rubber half metal oem units. Though i do need to create some sort of block outs for the adjustable end on the actual flanges that go to the upper mount. Because I noticed that there has been a bit of wear around the bolts. I'll take pictures of those when i get the chance to nake them.
CaliS80T6
Sep 12, 2009 09:20 AM
tolliver
Nov 23, 2007 12:32 PM
strangedays
Sep 29, 2007 09:53 PM
leebae
Sep 18, 2007 08:07 AM
leebae
Jun 17, 2007 10:28 PM
