Strange electrical issues!! 2017 S60 T5
Old Apr 30, 2021 | 06:41 AM
Billysledgehammer's Avatar
Default Strange electrical issues!! 2017 S60 T5
First it started off with my s60 not starting, and the ESC required service and TPMS required service. Then my taillight is showing an error. Then my city safety system is requiring service. Then my headlamps are showing an error. And when I'm driving my brake light flashes on and off for a second or two. Sometimes the engine starts, sometimes it doesn't. This is so far beyond my mechanical skill. What in TF is wrong with my car??
Old Apr 30, 2021 | 08:11 AM
I would check the basics first. How old is the battery and what condition is it in? It could simply be a bad battery for the CEM can turn off things less important if it thinks the battery is going dead or weak. Is it the original battery? Could easily be the original given the year of the car.
Old Apr 30, 2021 | 02:43 PM
I thought maybe that was what was causing it, I replaced the battery 2 days ago. Problem still persists. Is there a connection loose or something?
Old Apr 30, 2021 | 03:12 PM
It only starts up when I jump it do is it a bad alternator?
Old Apr 30, 2021 | 03:43 PM
Pretorien's Avatar
I would check the connection of the (-) terminal to the chassis. If it is loose/corroded/unsound that could cause multiple problems including no start.
Old May 2, 2021 | 08:58 AM
If the starter will only operate if you use jumper cables connected to another car - your "new" battery is dead or has a very poor connection to the positive cable or the car.
Do you have a voltmeter? Starting at about $7 - you need one to check voltages in the system. Static fully charged battery voltage is about 12.4 volts. Engine running the voltage at the battery should be at least 13.2 volts. Generally over 14 volts at the battery is bad also. If you start the car and the voltage at the battery does not go up to 13.2 volts or so (with the jumper cables disconnected) - your alternator is not charging the battery. (due to bad alternator, bad connections, belt missing, etc.)
https://www.harborfreight.com/7-func...gg_q=voltmeter
Old May 2, 2021 | 09:37 AM
Pretorien's Avatar
If the jump starts are done per the Volvo manual, (+) to battery +, (-) to chassis ground, this would mask any problems with the battery ground.
Old May 2, 2021 | 02:00 PM
It only needs to be jumped sometimes, not every time. When it does crank it struggles for a second tho. The battery despite being brand new shows 11.45v when the car is off and then slowly charges up to 12.5 when the car is running. The OBD II codes that its throwing are 060, 0103, 2226, and 240b. I'm not sure if the codes are the cause or if they are just a symptom
Old May 2, 2021 | 03:35 PM
A fully charged battery with no load on it should be ~12.4 volts. If you charge your battery, let it sit for a couple of hours disconnected it should be ~12.4 volts. Anything lower and your battery is bad. If the voltage is only 12.5 volts when the car is running - The CEM will turn things off to keep the fuel and ignition system running as long as possible -
What brand and size battery did you install? Hopefully a name brand size 48-H6
Old May 2, 2021 | 03:36 PM
Old May 2, 2021 | 04:03 PM
It is the correct battery size. Napa premium legend 9848
Old May 2, 2021 | 04:21 PM
If static voltage is less than 12.4 volts on a fully charged battery - the battery is bad (dead cell,mechanical connection inside the battery, whatever - it's just bad)
Old May 2, 2021 | 06:02 PM
Do you think I got a defective battery or that something else is killing the battery? I'm heting it looked at by a mechanic on Thursday btw
Old Jun 8, 2021 | 05:43 PM
Cars fixed. I needed a new ecm and a new module that's under the fuse box. 2k fix. Technician had no idea why it happened but could only figure that I jumped it with the cables on the wrong way (I didn't), or that it was struck by lightning.
StevenStowik
Dec 15, 2022 11:28 AM
Shawn DeWitt
Apr 24, 2021 06:25 AM
caball88
Aug 3, 2020 11:42 AM
tuross
Jul 30, 2019 12:47 AM
Wagon2006
Jun 21, 2018 10:50 AM
