Tach/ cluster
RE: Tach/ cluster
Hey Rob, I was checking out some other sites and others have been able to swap out the cluster no problems. For instance Canadian/metric to US/standard out of different models/year xc70/s60. Plugs were the same. To remove: start by removing the trim ring (snaps out by pulling outward), remove 4 torx screw, pull cluster out, disconnect cable. I did a quick search and found StrickerBros.com had an 'R' cluster for $250! (Oh wait, I shouldn't have told you that. I want it!)This is a used car parts salvage operation located in OHby the looks of it.
volvo5volvo
05-29-2012 05:46 AM
