Miss under load and jumpy tach needle
Old Jun 16, 2006 | 06:23 PM
van850's Avatar
Default Miss under load and jumpy tach needle
Hey All,I just purched an 93 850 non turbo.The problem I am having is there is a hesitation while driving and under load.All the tune up ignition parts are new(cap,rotor wires,plugs)I removed the coil to check for poor connection cleaned them all and re-installed them.Still the same problem.I am at a loss here.
I have talked to several people and they all say wires.(but they are new)I suspect a coil
Has anybody had this problem?Any help would be greatly appreciated.
Old Jun 17, 2006 | 12:05 PM
Default RE: Miss under load and jumpy tach needle
What brand are the Wires?
What brand are the Plugs?
Old Jun 17, 2006 | 01:57 PM
van850's Avatar
I had autolite XP3924 platinum.I have just put in NGK BKR6E,gapped at .029.The wires are jobber Bougicord.(checked resistance and they are good)
The tach seems to be better but I am still getting the hesitation.
I am starting to think it might be a fuel problem(new filter in place already)
Old Jun 17, 2006 | 02:00 PM
Do you have a fuel pressure Guage you can install and watch as you drive?
You might want to try Bosch Plugs.
Volvo's don't like many plugs besides Volvo and Bosch plugs.
Old Jun 17, 2006 | 03:03 PM
code33's Avatar
Check for any codes stored in the computer. If there are any, note them, clear, and drive around to see if they come back. I'm assuming that the check engine light is not on.
If you are indeed having any actual mis-fires, there may be codes stored. I'm thinking more along the lines of a fuel delivery problem. A weak fuel pump or worn out fuel pump relay may be the cause; no codes will be present any of these are the case.
Old Jun 21, 2006 | 03:24 AM
van850's Avatar
Bosch plugs and the problem is still there.Thanx for the help but I have to send it to the shop to be looked at.
Any other advise may still help.
0tt0pilot
Jul 31, 2014 12:50 PM
A&P
Dec 10, 2009 11:01 PM
amesinger
Mar 28, 2008 08:31 PM
DJboozeAlot
Nov 27, 2006 08:54 PM
