Terrbile Cold start problems - VOLVO V60 T4F
Old Aug 9, 2016 | 11:04 AM
fbeinfo's Avatar
Default Terrbile Cold start problems - VOLVO V60 T4F
Hi all and best Regards from Luxembourg
let me describe my problem with my V60
Currently I've a VOLVO V60 T4F (Flexifuel ) 132 kw. 1600ccm
The Car dealer nearly get mad, they don't find the error.
what happens.
When the car is off over night of switched of for a longer time with a cold engine, the engine start makes problems.
Means the engine starts immediately but then I get random misfires (Error P300) the MIL is flashing but it's not on steadily.
after 20seconds the error is gone and the engine runs fine.
But when I start and push the throttle a bit more than 2000rpm the error doesn't sometimes even come up.
IMPORTANT: The error doesn't come on LPG only on regular fuel, but in the cold start phase you must drive on regular Fuel.
The following works have been done.
- 2 coils replaced
- fuel injectors checked and cleaned with ultrasound
- spark plugs all ok
- compression excellent
- MAF replaced (problem still persists)
- Checked for Air Leaks (all ok)
the Long term Fuel Trims where at +19%
they are now back to normal means -1% After a 300km Highway drive.
Has somebody had already such an issue?
the mechanic told me the it could be probably somewhere in the Fuel Supply circuit.
means Fuel Pump - High pressure pump
Rail Pressure valve or Rail pressure sensor.
somebody can help?
Best Regards
Frederic
googletag.cmd.push(function() { googletag.display('div-gpt-ad-13'); });
Old Aug 9, 2016 | 11:19 PM
ssicarman's Avatar
When the injectors were checked did they check them for leaking?
How is the coolant level? Is it dropping?
Old Aug 10, 2016 | 01:00 AM
fbeinfo's Avatar
Coolant level was dropping 7000km ago. VOLVO Check and made a pressure test . but there was all ok. The Injectors had been removed and physically checked as part of the fault search. Also all working fine.
ECU ?? Probably
Temperature sensor?
fbeinfo
Aug 3, 2016 11:43 AM
Pouch
May 8, 2015 09:03 PM
trev0006
Nov 8, 2014 12:08 PM
gogomom
Jan 9, 2013 07:08 PM
arttu
Feb 15, 2007 10:16 PM
