Throttle body
Old Apr 26, 2022 | 09:03 AM
Vanni's Avatar
Default Throttle body
So I read on another forum that the 2003 s60 took the Bosch ETA throttle body which is programmed by turning the key to POS ll for 40 seconds. Is this true or would I still need to take it to the dealer to get the throttle body programmed?
Old Apr 26, 2022 | 11:19 AM
The bosch throttle bodies are plug and play. No download needed like to 99-01(04 some cars) Italian modules do.
However - very rarely is there is problem with a Bosch throttle - if they malfunction it's usually a connection problem (yes, you can have throttle codes that are misinterpreted) and is fixed (either after unneeded throttle replacement or before) by replacing part of the wiring connectors at the throttle housing. Volvo has a service solution (new wires) for that fix.
Old Apr 26, 2022 | 11:22 AM
Vanni's Avatar
I have a throttle body that I got from the junkyard but I got a little of water in it. Do you reckon that it still works?
96turbo850wagon
Intake, Headers and Exhaust
Apr 29, 2015 08:48 AM
cdurnal
Oct 28, 2008 06:45 AM
johnnyrock
Nov 24, 2006 10:59 AM
T4
Sep 17, 2006 11:43 AM
wavewright
Apr 9, 2005 06:15 PM
