Tire rubbing in plastic wheel shield..
Ever since i bought a used 2005 S60R there seems to be many problems.
1. humming from underneath the car in rain.
2. tire rub on plastic shield, when i turn more than 3/4 of the steering wheel.
is there anything i can do to prevent this. its annoying to hear the rubbing.
The tire rub issue your having is something ALL P2 R's have to deal with. The OEM Pegasus wheels we have needed to fit over the Brembo's so were stuck with a turning radius about as large as a aircraft carrier's and wheel rub. First, check your bump stops to see if there bad. This will not fix your problem but will lessen it by taking away how far you tires will turn side to side. What most have done, is either stop turning the the steering wheel to full lock, or installing 5mm spacers on the fronts. That will fix all together for you as long as your bump stops are in good shape.
celjock
Apr 16, 2011 02:55 PM
