Tranny Question
Old Oct 14, 2006 | 02:35 PM
MK1's Avatar
MK1
Default Tranny Question
Can anyone explain this one...
Every now and then when the car shifts from 1st to 2nd or 2nd to 3rd, it almost seems like it misses a shift or something and the car just revs way up...than it catches and its fine. It has been starting to do this about every other day or so. I did have the software upgraded for the transmission back a few months ago.
With my axle needed replaced, a check engine light on and a goofy transmission, is it time to cut my losses on this car? It has 99K on it...I'm in for the big timing belt change here in a few months as well. Any advice??
Old Oct 14, 2006 | 02:51 PM
Default RE: Tranny Question
Sounds like a definate problem.
But if there is codes in the transmission it will shift funny till either it is fixed or the codes are cleared.
Get the timing belt inspected I have only seen Few cars actually go to 105,000 on the stock timing belt.
Also make sure the tensioner and Idler get replaced.
If the Belt breaks then you will be looking at about $3,000 to get it fixed.
Old Oct 14, 2006 | 03:11 PM
MK1's Avatar
MK1
Thanks for the info...
Will the tranny codes cause the "Check Engine" light to come on or is that another issue?
Old Oct 15, 2006 | 12:28 PM
A code in the tranny will cause a check engine light as well.
Old Oct 15, 2006 | 01:49 PM
MK1's Avatar
MK1
Thanks.
It's going in tomorrow. I'll let you know how it turns out.
Old Oct 16, 2006 | 10:27 AM
adub96's Avatar
I have the same problem, but its only aftert agressive driving then driving slow for a bit then agressive driving again. I'm speaking of the tranny shift dealy. I know on the Vw's that the drive by wire causes this same problem. I need to change my timing belt that reminds me.
Old Oct 16, 2006 | 12:52 PM
thullz's Avatar
I am the second owner and have no records on the car. Is it possible to determine if the timing belt has been changed? $$ cost? I have an 01 S60 2.4. I also experienced the delayed shift problem once. I wonder if its a sign of things to come or a freak thing.
Old Oct 16, 2006 | 08:49 PM
You can inspect the belt and see if it has cracks.
How many miles on the car?
The tranny might need a software upgrade or be a freak thing.
Old Oct 17, 2006 | 05:36 PM
thullz's Avatar
140k km on the car. Is it a costly repair?
Old Oct 17, 2006 | 09:13 PM
140KM should be about 87,000 miles.
It might not have been done yet.
About $300.00 to $400.00 US.
Old Oct 18, 2006 | 12:42 AM
Ihatespeedbumps's Avatar
I would go to your local dealer and see if the can apply a TCM upgrade that will fix your symptoms. It's probably the cheaper than any other options you have.
Old Oct 19, 2006 | 04:23 PM
joshskywalker's Avatar
I am having the same problems as MK1 with the tranny missing / slipping..
Mk1 please update this post if you /when you find out what is wrong and the fix.
If anyone has any other idea please post.
"Can anyone explain this one...
Every now and then when the car shifts from 1st to 2nd or 2nd to 3rd, it almost seems like it misses a shift or something and the car just revs way up...than it catches and its fine. It has been starting to do this about every other day or so. I did have the software upgraded for the transmission back a few months ago. "
Old Oct 20, 2006 | 11:49 AM
MK1's Avatar
MK1
Sorry for not updating. I have not got it checked out yet. My car was in for a new axle Monday, but the CEL went off and it shifted fine all weekend. It has not done it again since. [&:]
This car does have an adaptive transmission, right? My wife is the one who drives the car all the time...could it be the tranny is cofused at my different driving style? Of course, I drive it right!
Old Oct 20, 2006 | 01:48 PM
I am not sure if s 60s have adaptive transmissions? When you get you car looked at please post solution to or answer you get and I will do the same.
Can anyone explain adaptive transmission?
thanks
Old Oct 21, 2006 | 01:11 PM
Yes the transmission is adaptive.
It adapts to driving styles. But it shouldn't go real wacky when someone else drives it.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
v40 blue
Apr 27, 2007 01:10 AM
wagoon
Mar 14, 2007 03:17 PM
Omead
Mar 31, 2006 10:23 PM
igtc
Mar 9, 2006 10:45 PM
