V60 smoking
Old Apr 19, 2024 | 06:21 AM
Iano61's Avatar
Default V60 smoking
My 2016 V60 is smoking badly from exhaust when warm and uses a lot of oil which I think is being continually burn off it has a ford D3 diesel engine and I have just changed the injector seals on advice from local garage but still smoking ???
Old Apr 20, 2024 | 02:01 PM
if its smoking and consuming oil, that suggests a piston ring problem. If a diesel just smokes then its running rich. How far do you go before needing to add a quart of motor oil?
Old Apr 21, 2024 | 09:12 AM
Iano61's Avatar
Hi probably about 200 mile and can not read oil level on dash as the light is dark if you know what I mean
Old Apr 28, 2024 | 10:52 PM
Niklas11Braun's Avatar
It could be worn-out piston rings or valve stem seals that are letting oil get into the engine, leading to smoke.
Plus, the turbocharger or the turbo oil seals could also be culprits. A malfunctioning turbo can cause both smoke from the exhaust and oil consumption.
JBoldt
Jun 1, 2025 10:19 AM
Iano61
Apr 21, 2024 05:31 AM
urgiv
Feb 17, 2024 02:55 AM
JoeMed
May 3, 2022 09:04 PM
ronsivillo
May 10, 2017 06:18 PM
