vadis codes interpretation and notes - Pleasr some HELP here!!!
Hi to all...
I am trying to use Vadis to see the "part numbers" of some parts to buy and import to Brazil.
The problem is that the "Vadis", to my motor (5cilT) says that there ar two types of "oil pumps", and the code shown have one "note" in the side.
The point is: what's the significance of this "note"? Is there any difference between the parts, when the "part number" is always the same - (30650144)?
The note shows this: "ENG-2696352 (9458426)" thoes this mean something?
Hi. My S0 is the 2.0T, year 2001 model 2002, vin nmbr. yv1rs49k922096059.
My mechanic sayd that probably the low oil pressure is beacuse of oil pump malfunction (he also double checked pressure, changed oil, filter, etc and problem persists). But he sayd too that if it does not work the engine is condemned! Can this be possible?
I hope there's not the point...
the car has only 64.000 miles (or 103.000 km here in Brazil), the engine is running smoothly and no smoke, vibration or oil consumption... must be the pump!
Thanks the help.
Thanks the help.
ok found it, the part number is correct its 30650144
it is built for 2 different engine model numbers so this is where your confusion is.
one thing to keep in mind is once you have it all out clean or replace your turbo oil lines its inexpencive and itll probably save you a lot of pain later on.
hope it works out!
hope it works out!
