Vibration.
Old Sep 14, 2008 | 10:25 PM
SeanSinger11's Avatar
Default Vibration.
Cars runs great until it hits 60-65 miles/h and even the slightest bit on acceleration will cause the car 2 vibrate, i have no clue what this is, does anybody have a true solution, i know most people have replaces engine mounts tie downs, could this be the CV boots?
Old Sep 15, 2008 | 12:53 PM
akorcovelos's Avatar
Default RE: Vibration.
had the same problem with my old BMW, it was RWD but that may not matter. Start with the obvious, how are the tires? When was the last time they where balanced? The fact that the car is smooth up to 65 (the exact speed mine started vibrating) makes it seem like a rubber part somewhere, because it absorbs the vibration until 65 when it hits the right harmonics and can't absorb any more thus you start to feel it. Does it vibrate when braking, coasting,or only when you accelerate?
Old Sep 15, 2008 | 05:18 PM
I would have the front axle inner joints inspected.
Old Sep 15, 2008 | 09:36 PM
The car is going in tommorow, i guess our mechanic says it can be anything from a bent rim to allignment, but would this vibration cause my check engine light to come on also? Because i was cruising up to 65 and i started feelings the vibration, pops on the check engine light for the first time. any ideas? also i can feel vibration VERY slighty, aside i still feel it, in normal driving also. But no i do not feel it when i brake or let go, only when my foot pushes the accelerator.
Old Sep 15, 2008 | 09:53 PM
It could also be misfiring which would throw the check engine light on.
Old Sep 16, 2008 | 11:02 AM
hooked it up to the computer, said catalytic converter, this wouldnt be the cause of the vibration tho..
Old Sep 16, 2008 | 02:22 PM
gtco3dfever's Avatar
A friend of mine had a car where the cat converter was old enough that the innards "imploded" causing it to clog the exhaust.
Exhaust gasses were trapped, so to say, making the engine not run correctly.
Just a thought............
Old Sep 16, 2008 | 06:45 PM
Possible but then you can usually hear a change in the exhaust noise.
Old Sep 16, 2008 | 10:53 PM
come to find out both my front wheels were bent, we switched them to the back car runs smoother, now u can barely feel it in the back.
ocean238
Apr 17, 2008 06:20 PM
JimKW
Jun 14, 2005 06:38 PM
CFGVolvo850
May 18, 2005 10:59 AM
alecw81
Mar 7, 2005 10:47 PM
Macgregorguy
Dec 19, 2004 03:48 PM
