Volvo S60 camshaft lines
Old Nov 14, 2018 | 12:40 PM
Chase Forman's Avatar
Default Volvo S60 camshaft lines
Today I was working outside on my friends volvoS60 2002 2.4 and I had to take the head off because there was a bent valve due to timing belt falling off. o replaced the bent valve and then when I put it back together one of the exaust ambifold pieces was bad so I took it out again and I found this on cylinder number two would I be able to still have it run it is or is it because the camshaft is bent due to the broken valve thanks
uys.
Old Nov 14, 2018 | 07:07 PM
ES6T's Avatar
Doubt your cam is bent. More likely something caught on reassembly. A machine shop can tell you if they can fix it.
nero
Aug 1, 2015 11:54 PM
nuclearseal
Feb 9, 2013 10:52 PM
ridextream53
Feb 12, 2011 08:36 PM
motofrk75
Nov 17, 2010 09:58 AM
frank17
Apr 26, 2009 03:40 PM
