Warped Air Box
Warped Air Box
Whilst replacing my air filter, I noticed that the air filter housing looked warped. Presumably after a previous replacement of the filter, the side tabs were not aligned correctly hence putting pressure on the housing & combined with the heat -> caused it to warp.
Any tricks, or do I need to buy a new housing? Are they expensive?
I wouldn't worry. I don't think anything is wrong. Mine did the same thing the first time I replaced the air filter. It's not warped in the permanent sense. Those tabs just have such a tight fit, especially the middle one. Don't be afraid to force it. Try using a screwdriver. That plastic can take quite a bit of abuse before it breaks.
