Water in the drivers side headlight...
Old Mar 20, 2011 | 12:14 PM
ecoughlin's Avatar
Default Water in the drivers side headlight...
New to me. S60. 2002 2.4T AWD. What is involved in fixing this?
Old Mar 20, 2011 | 03:38 PM
MattyXXL's Avatar
Involved in getting the water out, or involved in stopping the water from getting in?
When did the water appear in the light, after rain, or did you drive it through a flooded area?
Old Mar 20, 2011 | 11:52 PM
J. A. Higgins's Avatar
Barring anything being broken it could be from a bad lens seal or other seal. How much water is in it? A lot? A little? Enough to house a goldfish?
Old Mar 21, 2011 | 04:45 PM
ecoughlin's Avatar
thanks, Heh, no goldfish. Just looks like condensation on the inside of the lens. Just from rain. Did not drive it through a flood.
Old Mar 21, 2011 | 05:18 PM
The inside of the headlight housing can get pretty hot with headlights are on and air pressure inside can rise. Then when the lights are turned off the housing cools and, if it cools rapidly, can create a vacuum. If there are any leaks in the seals it is possible the housing can draw moisture into the housing.
Old Feb 4, 2015 | 12:12 PM
Bossdog's Avatar
Just replaced Dust Covers back of headlight on 2001 S80 T6 driver side, they had moisture running down the inside,so far they are clear as a bell. Covers are about $12.00 each.
ljarch
Mar 31, 2011 07:39 PM
TiAgTouring
Mid West
Oct 1, 2010 01:30 PM
ToledoVolvo01
Apr 30, 2010 09:34 PM
mcaanda
Apr 27, 2010 01:00 PM
Bruce Wayne
Jan 2, 2009 01:45 AM
