Wheel Swap
Old Feb 21, 2017 | 12:17 AM
trooper616's Avatar
Default Wheel Swap
I have a 2004 Volvo S60 and my mom has a 2002 Volvo S60. The wheels on her car are 16 inches and the wheels on my car are 15 inches. I like the rims on my moms car much better. Could I just swap all four wheels out and have no problems on either end? One car will get the bigger wheels and the other car will get the smaller wheels. Will it make any difference? And would I have to do anything to be able to swap them?
Old Feb 21, 2017 | 08:47 AM
You should be good to swap - both cars have the same 5x108 bolt pattern and center bore and similar tire rotational sizes - check your tire pressure chart on the door frame or fuel filler door and you should see the suggested tire sizes - ie "plus one" for 195/65-15s is a 205/55-16. Both wheels should say ET43 (as the offset) if they are 6.5 inch wide rims. Just make sure the 2004 doesn't have any clearance problems over the front brakes - some of the sportier trim models have larger front discs which require a 16 or larger wheel
Old Feb 21, 2017 | 09:39 AM
trooper616's Avatar
Thanks for your reply. I'll definitely check on those things now that I know it's possible.
hogbygardd
1998-2000 model year V70
May 5, 2013 12:35 AM
eurovin
May 4, 2013 10:52 PM
RDP3430
Mar 18, 2011 04:56 PM
matt01
Feb 8, 2010 10:25 PM
info2x
Oct 31, 2006 12:11 AM
