Wheel/Tire noise from my v60
Old May 26, 2017 | 12:51 PM
arellaford's Avatar
Default Wheel/Tire noise from my v60
I have a 2015 v60 T5 with about 65K. Lately I've noticed what sounds like a rubbing/ sometimes clunking noise at low speeds, and even at a stop with brakes applied. I asked my mechanic to check it out (of course he couldn't hear anything). He thought it might be the tires (Pirelli P6s). He doesn't think its a wheel bearing.
Has anyone else experienced this?
Thanks.
Old May 26, 2017 | 02:10 PM
typical tire noise changes with road speed - but never a clunk. If you hear rubbing, I'd look for something related to the brakes (ie a bent "backing plate" - that metal shield behind the rotor), worn pads etc. Does the noise change when you apply the brakes while driving at low speeds? other sources of clunks include suspension bushings, axles/CV joints (clicking and thumps when turning around in a driveway would point to the CV joint) and finally engine/transmission mounts. I'd also look at the exhaust system to see if its misaligned or has a torn hanger. I own a 2012 VW CC with 65000 miles and it has some subtle clunks from time to time but the car drives firm and true. I just associate the noises to normal movements in the suspension bushings and CV joints.
Old May 26, 2017 | 04:32 PM
arellaford's Avatar
Great suggestions. I'll check those.
Thanks.
Cezarila
Mar 15, 2018 07:46 AM
Pouch
May 8, 2015 09:03 PM
kcw12
Jun 10, 2008 08:48 PM
daisydaisy
Jan 26, 2006 11:52 PM
