Wheel Wobble
Old Oct 26, 2010 | 05:59 PM
jcoudrain's Avatar
Default Wheel Wobble
I have a 2006 S60 T5 with 130,000 miles. There is a vibration coming from the passenger-side front wheel for the last 50,000 miles, and I am having a hard time getting it fixed. The brake on the same wheel also vibrates, but only when braking from high speeds.
It is hardly noticable below 30-40mph, but at 60-80, it is bad.
I have replaced the strut, sway-bar links, rotor and pads, and also replaced all four wheels and tires. The front-end has also been aligned. None of this has had any effect on the vibration. Is there something that could be causing both problems?
HELP!!! Where should I look next?
Thank you for any assistance, I cannot waste another minute at the dealership.
Old Oct 28, 2010 | 01:10 PM
patsfn2's Avatar
when you step on the brake and the car is slowing down do you get sort of a clunking feeling???? if so you have the same symptoms that I experienced with my 960....I had to replace the upper and lower control arm bushings as they originals were wore out at 248,000 miles.....search this site for information about upper/lower control arm bushings....i think this might help!!!
albert89
2001-2013 model year V70
Feb 9, 2015 11:23 PM
Kiwi84
Dec 2, 2012 02:17 PM
mdebarro
Apr 5, 2010 04:36 PM
2k5s40MN
Apr 19, 2008 09:45 AM
WagHag
Jan 2, 2007 09:09 PM
