where's the oil filter??
Old May 22, 2009 | 08:23 AM
99k's Avatar
99k
Default where's the oil filter??
I give up ... this is my first volvo and I'm very mechanically inclined but I cannot find where the darn oil filter is located.
I have an 06 S60 AWD. FCT Groton who sold me the filters wasn't any help. I noticed there is also a huge plastic shroud that isolates the road from the engine/tranny ... hoping this does not need to be removed.
Thanks for assistance!
Old May 22, 2009 | 01:01 PM
TIPSP's Avatar
Got Boost?
Check here...http://cvolvo.com/Central/Repair/B5254T.html
should be under the car.....
Last edited by TIPSP; May 22, 2009 at 04:06 PM. Reason: Forgot to post pic from the site...
Old May 22, 2009 | 03:21 PM
S60 R's Avatar
Don't know about that link, it didn't specify the S60 and its not accessible for the top of the engine compartment.
On the S60 that plastic shroud on the bottom needs to be removed first. Then you'll see the filter canister on the passenger side of the engine block.
Old May 22, 2009 | 08:10 PM
99k's Avatar
99k
Well that explains why I couldn't see it. Maybe this is premature, but the Design for Servicability seems ill conceived. This entire plastic covering must be removed? I'm thinking a quick modification with a hole saw may be in order.
Old May 24, 2009 | 10:30 AM
mcleantmw's Avatar
Vary common on many of the Euro vehicles requiring removal of the splash pan to access the oil filter housing..........both my Volvos S60 and V70 have this. On my Benz, the oil filter housing is top side in the engine compartment with super easy access, however, the oil drain plug is behind the engine splash pan so alternatively some people use a hand pump to remove the oil during oil changes through the dip stick tube.
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
NCS60
Apr 5, 2007 12:53 AM
nationm
Feb 12, 2006 10:09 PM
