Windshield washer woes
Old Jun 9, 2024 | 06:22 PM
Hillboy's Avatar
Angry Windshield washer woes
My 2017 s60 T6 has been an excellent driver, but recently the windshield washer quit working (the headlight washers operate a bit). The reservoir tank was almost empty, but when I added fluid, it drained out onto the ground. I then replaced the tank, but the draining continued with the new tank. All hoses appear to be in good shape and clear of blockage. I would suspect the pump, but the headlight washers operate. Any help would be greatly appreciated.
Old Jun 13, 2024 | 03:17 PM
here's a parts diagram
https://www.tascaparts.com/v-2017-vo...her-components
looks like there's an o-ring between the washer pump and the reservoir....
Old Dec 29, 2025 | 07:20 PM
Hillboy's Avatar
Default Windshield washer woes - solved
Good suggestion on o-ring between washer pump and reservoir, but the solution turned out to be a bad connection buried in the left-front fender near the cockpit. The car had been in an accident several years ago and the body shop didn’t “snug” the connection tight enough. Took awhile to find someone (other than dealers) who had the necessary wiring diagrams. Thanks to all!
Norm King
Jul 7, 2021 03:11 PM
Ragtop
Jun 18, 2010 05:40 PM
apriliaguy
Oct 30, 2008 08:23 PM
raybun
Jul 19, 2008 07:52 PM
wjkjr
Jan 7, 2008 11:32 PM
