Xenon low beam failure
Just picked up a 2004 S60 R, 80,000 miles and seems to be in pretty good shape. Getting a Low Beam Failure on the message board. New to xenon lighting and when driving at night, both lights due light up and I can see fine down the road. I hit the high beam and only the Drivers side bucket seems to move and not passenger side. I don't know if that is correct or not, figured pass side might be permanent fixture down the road.
Xenon doesn't change wattage like a normal light when hitting Low/High beams, correct? Looks like just the bucket swings up or down.
I did buy 2 low beams (H7) but couldn't find where they go so returned. I thought the inside light was low beam as they didn't work but upon taking it out and putting it back in, those Daytime Running Light is now working.
Thanks. Scott
Thanks. Scott
Well, Daytime running lights (inside light next to grill) no longer work, once again. When they are out, the Xenon lights stay on during normal driving and the light swith in the OFF position. Is that normal?
I will try to find the 2 wires you mentioned and see if they are connected or not.
Thanks.
Thanks.
I dont think you can turn the xenon lights off unless you have the daytime running lights on. I have the same model and year car as you. The xenon lights should only be on in the (from left to right) first and 3rd position. The middle light with the little green indicator light is your running lights and your xenon lights will be off when in this position.
The daytime running lights SHOULD be, although Ive never payed that close attention, off while the xenon lights are on. I dont know why I guess its the same reason the fog lights cannot be on while the high beams are on.
I hope this helps as I am kind of finding your post a little confusing lol
Thanks. Scott
Thanks. Scott
Yeah. Started looking into this last night pretty good. Kiss (Keep It Simple Stupid). After taking a few things out last night, figure I would look at fuses, sure enough right low beam fuse was bad. Replaced and now low/high beams both work and buckets both move/change. So that is correct. Then looked in manual and it states that DRLs will be on depending upon the lights conditions. Xenon will come on, DRLs will go out if it is a little dark. That might be my main problem. Working 2 jobs, don't work on car much during normal hours.... Lol
But message still saying bulb failure - low beam. I tried doing the reset trick to clear message but no go.
I do have a switch on directional shaft that says 'reset' but manual does not say how to use. I tried the, key on 1, push/hold trip, then key to 2 within 2 seconds. That did get rid of my 'regular service' message but not low beam error". Today we work the little things.
Thanks to all replies
Of the 2 circles or cups, 1 is smaller then the other and these are the DRLs, inside light next to grill. I thought they were low beam. The larger cups are the xenon. Drl's are differnt bulb then h7. So I don't think h7 fit our model with optional xenon's.
Thanks
Thanks
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
llcoollam
Apr 24, 2006 06:54 PM
